Golden_HVAC
Jan 18, 2014Explorer
A normal RV water pump can take water from 4' below the pump location. It helps if the pump and tank water level are close while the pump is taking in air, and getting primed, but it is not a requirement to have the pump below the water level while pumping, because it is a diaphram pump, and can take in negative water pressure up to about 10' of suction depth.
So I would get a normal 12 volt RV pump, attach a 10' hose to both ends and pump the water either into the fresh water tank in the RV or into the fresh water inlet. You can even get really clever and mount a additional tank on the RV roof, then fill it with the pump, and have a valve going to the fresh water tank, letting it gravity fill as you need it. In theory, you could fill the 55 gallon tank 3 days a week, and fill the fresh water tanks in the RV (including a new roof one) only a few days per month, saving time.
Fred.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
