BTPO1
May 01, 2015Explorer
You need to start at the source (Tank) and follow the water line to the pump. Ensure all of the valves in the line are open and all drain valves are closed. You may also have a valve somewhere that says city/pump or something like that. If so make sure if using the pump that it is set to pump. On mine a lot of times I forget to open the valve from the tank, thus no water.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
