LangsRV2
May 02, 2015Explorer
mogman wrote:
Winterizing valve still open?
We looked for a winterizing valve, there isn't a one ended hose that we can find. There is a brass fitting between what appears to be the pex coming from the tank and the pump tried it both directions but it didn't do anything. I can't figure out what that valve would even be for. The tech did show us the water tank winterizing pass valve. It's behind a screwed on pannel now. However even if this happened to be in the wrong position for summer then we should still have water pressure in the rest of the rv.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
