xaugievike
May 02, 2015Explorer
No water from hot or cold sides? Like none at all or a slow trickle? One thought I had was that your hot water tank was filling up?
Did you fill your fresh tank all the way?
I've never seen a manual valve to switch between city water and tank...
Locate your water pump.
On the inlet side (where it draws from your tank) look for a quarter turn valve...that would be where a winterizing hose would be attached. Turn it 90 degrees so it draws from tank (handle would line up with tank hose)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
