Cloud_Dancer
May 02, 2015Explorer II
Now, I'm curious. I'm trying to think of how the water circuitry is designed, such that you can access the same distribution system from city water and also with the RV's water supply,....without a selection valve. There has to be at least a shutoff valve where you connect the city hose.
Without the manual, I suppose I would make sure the pump itself was in good working order, even if I had to remove it and stick the pickup hose in water and turn on the pump.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
