Cloud_Dancer
May 02, 2015Explorer II
OP, if you assume that your water system is the same as the posted diagram, diagnosing the problem should be a piece of cake. Disconnect the line on the inlet side of the pump and suck on it to find out if you get water or air.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
