Old-Biscuit
May 02, 2015Explorer III
bob213 wrote:
Would a bad check valve on the city water inlet cause this? Old-Biscuit, I think you posted on this recently.
Would cause water to leak out city connection
OP has an air leak on suction side of pump......either via winterizing kit, pump suction strainer/pump fittings cracked-loose or loose suction line fittings.
Priming suction side of pump would be a good test of nothing obvious.
Pump freeze damage due to improper wintering ????
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
