dms721ExplorerOct 15, 2019Water pump issueMy water pump sputters anytime I turn the faucet on. It does pump but seems to pick up air and sputters both hot & cold. I did try just a 5 gallon bucket of water into pump and still does it.. Pump ...Show More
wa8yxmExplorer IIIOct 15, 2019If the pump sputters there is an air leak. a small enough hole may not drip water but will leak air.. Inspect the water line between pump and tank.ALso remove line from tank if you can there may be an outlet strainer and it may be clogged.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
Related ContentWater PumpTowing lights issueWater Pump IssuePump issuesWater Pump Failure Traveling To The Eclipse
