My water pump sputters anytime I turn the faucet on. It does pump but seems to pick up air and sputters both hot & cold. I did try just a 5 gallon bucket of water into pump and still does it.. Pump ...
Another thing to check is the short hose line (if you have one) to be used for sucking anti-freeze into the system. If the cap on that line is loose then air can be sucked in.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
