It is an intermittent issue. After using water, the pump shuts off as normal. But other times every little while the pump starts and runs just a couple of seconds. If it starts it continues to do so. ...
Trace all the plumbing you can get to with the pump on.
In many ways a small leak is worse than a big leak because big leaks are obvious and typically found quickly. A slow drip can go on for a long time and cause damage.
This is one reason, we prefer to use the pump over connecting to city water. If we hear the pump cycling and no one is using water, it's time to find out what's wrong.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
