dougrainer
Dec 27, 2016Nomad
If you ran out of water. Then filled the tank and now you have less pressure and the pump never shuts off. That points to a clogged Water Pump filter. When you run out of water, that allows plastic debris in the tank to be sucked into the Water Pump filter. That restricts the correct flow of water to be pulled from the Fresh tank. Check the filter. It is connected to the inlet side of the water pump. Doug
PS, if this is the case, the filter did its job.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
