wmoses
Apr 15, 2014Explorer
danager wrote:
I have the rubber mounts, soft hoses, foam insulation and accumulator tank. I can still here the pump...
But I bet it is quieter than without all that stuff. ;)
OP - I have the accumulator tank as well as some rubberized foam under the pump and the noise is cut down significantly in addition to the pump not cycling on as much as without it. In short, anything you add to silence the pump will cut down the noise to some degree, so yes it works.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
