olympicman wrote:
Again thank you wnii and dougrainer,
I bought the monitor panel with the switch for water pump as I wanted to keep the whole thing looking like a clean install and have to remove the old system completely. I will look into trying to retro fit the old pump switch into the new unit or buying a new switch.
Another thought, can I bypass the Intellitec controller completely and just have the new on/off switch operate the pump and have the other two switches inoperable? The pump controller is mounted right by the OEM tank monitor panel.
Yes, the only difference will be the See Level switch will complete the ground circuit. So, you will wire the 12 volt positive from the Intellitec controller to the Positive of the water pump. Then connect the ground pump wire to the (switch) wire at the controller. Doug
