jannie4's avatar
jannie4
Water system going crazy help!!
water pump runs every 13 seconds abt when turn on, no obvious leaks. decided to live with. THEN decided to just hook up to the city water at the camp site. seem to do fine. but noticed later not right water pressure coming out of faucets, and toilet almost no water when flush. go out check there is water (not a whole lot but some down the place where you normally but in the water for your tank. What's going on??
ideas of what to check? thought hooking up to city water would solve problem doesn't. thanks
  • city water intake thing (connection). There is a check valve on the backside of the connector. You don't say what year your rig is but my 2020 Vista had a plastic connector and leaked when I got it in 2021. Replaced it with brass fitting and been fine since.
  • ok thanks checked outside today and when the pump is on I noticed that water coming out of the city water intake. the pump cycled before on off I had tried hooking up to city water. if ckeck value easy way not want to tear water pump apart? or is it our city water intake thing.
  • schlep1967 wrote:
    I'm thinking the check valve at the pump has failed. When running the pump it allows the pressure to drop as water leaks back into the tank. When hooked up to city water it allows water to go into the on-board tank overfilling it.
    X2
    Ken
  • my bounder had a small/slow leak where a valves O RING HAD A small crack and would let system depressurize by leaking water into the FW tank, and would periodically repressurize the system..
    bumpy
  • I'm thinking the check valve at the pump has failed. When running the pump it allows the pressure to drop as water leaks back into the tank. When hooked up to city water it allows water to go into the on-board tank overfilling it.
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 21, 2025
