da_bees
May 28, 2013Explorer
dieseltruckdriver wrote:
Our Arctic Fox is an older one, but the fresh water tank outlet is on the side of the tank, about 3/4 to 1 inch above the bottom. They can't really go any lower.
I have never put antifreeze in the fresh water tank. It is like an ice cube tray only bigger. They never break, my almost completely empty plastic tanks haven't either, even at 30 below.
I don't anylonger but in order to get antifreeze in all of plumbing I did before installing a bypass. Heard about too many busted fixtures and lines where water remained after lines blown out with air. I believe keeping every thing wet while in storage prevents seals drying out. I can also pump antifreeze into everything much quicker than evacuating system. Comes down to preferrance I suppose.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
