evy
Apr 18, 2016Explorer
Water tank question
Hi everyone, I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250. I have some questions about the clean water tank. I don't want to install a 12v level indicat...
beemerphile1 wrote:evy wrote:beemerphile1 wrote:
If you can see the tank, you can see the water level.
You need a drain at the lowest point of the tank, the bottom.
So under the tank right in the middle is the lowest point, but how would I have access to open the valve? my tank is installed above the insulation so if I install the valve under the van there's a chance it might freeze right?
Install the drain so the valve is inside and only a pipe extends underneath. An empty pipe won't freeze.
