evy
Apr 18, 2016Explorer
Water tank question
Hi everyone, I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250. I have some questions about the clean water tank. I don't want to install a 12v level indicat...
evy wrote:
Ho really!? After the pump is where the city line would be tapped? Do I have to install a check valve so it doesn't go back the pump? I'm sure water going back through the strainer is not a good idea.
But it makes total sens, the water coming from the city line is already pressurized so my pump is not needed, logically I could install it anywhere, as long as it's tapped on the cold water line right?
But let say I'm leaving a camp site and I'm going boodocking, how will I fill my tank with the city water line before leaving? through the gravity fill hatch?
By the way no I can't move the tank at all, there's 3 inches on that side and it's where I plan on putting my 1 litre drinking water bottles :-/
I realize I need to draw a plumbing plan, I will do that and post it on a new thread, hope you all can take a look at it.
