evy
Apr 18, 2016Explorer
Water tank question
Hi everyone, I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250. I have some questions about the clean water tank. I don't want to install a 12v level indicat...
CapnCampn wrote:
I think your last drawing looks pretty good, just 2 comments:
2) if you want to be able to fill your fresh water tank from the city fill line, add a line with a valve from the city fill to the pump inlet (just bypass the pump with a valve in the bypass line). I'm planning on doing this sometime for some reason. It's not necessary since you can just put the hose or an adaptor down the gravity fill. :)
That's all I got.
CC
