Hi everyone, I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250. I have some questions about the clean water tank. I don't want to install a 12v level indicat...
I think I would lean toward not having a water trap if at all possible. You should have a constant downhill from the hatch to the tank.
I agree that drilling the 2x4 shouldn't hurt anything, the load will generally be spread around by the bed base. If you are concerned, you could reinforce the 2x4 under the hole.
CC
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
