Memphisdoug's avatar
Memphisdoug
Water Tank Repair
Due to some shoddy work from a previous owner I now find my water tank has a couple of small holes in it. They were caused by the tank shifting and coming in contact with a couple of sheet metal screws. The holes are located in the corner transition of the tank from the bottom to the side of the tank. Can I fix these by heating the surrounding area with something like a soldering iron to melt the holes closed or do I need to do something else? Like I said, they are small holes the size of a sheet metal screw. Once the holes are fixed I plan to do something to keep the tank from moving around so the problem doesn't happen again. Right now, it is just sitting on a piece of plywood between the frame and crosspieces. Thanks in advance for any help.
  • Black ABS - PlastiMend
    White polyethylene - probably needs to be welded.
  • Depends on which water tank. Is it the fresh water, grey water or black water tank?
    The grey and black tanks are probably ABS and you need to use an ABS cement for that. JB Weld, mentioned earlier, makes an ABS cement. Lowes has Oatey ABS cement, 8 oz can for under $5.50. Both will do a permanent weld on ABS by softening the ABS and welding it together. If done carefully you well never see the "patch". Been there, done that.
  • How about 3M 5200, cures under water and is practically indestructible.
  • Gjac's avatar
    Gjac
    Explorer III
    JB weld makes an adhesive for water, I would try that first. I never had much luck or skill with melting material and filling holes. Shoe Goo is another glue that bonds well to most materials. I would sand and solvent wipe the area to be bonded first. As a last resort I would use a screw with a small o ring under the head an screw it into the hole.
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 16, 2025
