DrewE
Mar 05, 2018Explorer III
RV water heaters typically are set to 140 from the factory. If Doug says otherwise for this model, believe what he says and disregard what I've written. (That's good advice on most of these sorts of issues, truth be told.)
One of the two thermostats in each pair is a high temperature safety cutoff, in case the normal thermostat should fail. The other is the "real" thermostat.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
