With two flooded lead acid 125Ah batteries being charged by two 100W solar panels the draw from the fridge and freezer would take the batteries down to 50% SOc after two days and no actual use of the fridge. With a 3-way fridge the juice to power the fridge electronics is very small and with our prior camper going for weeks with only two 100W panels was not a problem and we did not take a generator.
When I replaced the lead batteries with lithium phosphate ones of equal capacity I found that the solar was better able to keep up with demand as the controller could provide a higher level of charge and the batteries charge much faster and so make better use of available light.
I want as much battery capacity as will fit in the RV and as much in the way of solar production on the roof as I can find space for on the roof. Panels are cheap at roughly $115 for each 100 Watts of panel output. By far the most expensive aspect of adding solar is doing the wiring runs inside the RV.
