Just from being flat you would lose more than 6 watts out of 720. Then add heat loss.
Heat loss might be a bit less with panels flat (not sun direct) so pretend you lose 5% instead of 10% 5% of 720 is 36 watts. Say 5% from being flat in June in Arizona for another 36 watts. panel output now 720 - 72 = 648w.
If panels were 720 out and wiring loss is 2%, 2% of 720 is 14.4 watts. It just doesn't work out right.
That 714 must be from something else. Whatever, your set-up is working. Not so sure about the readings for what is measuring what though.
