cliffy49 wrote:
I have read where folks suggest any where from 1 to 2 watts of solar per ah of battery. My question, is this based on battery rating (ie 215 AH) or is it based on useable amp hours(105)?
All replys are greatly appreciated.
A poorly thought out rule of thumb. As likely to give you an undersized system or an oversized system. Pretty good chance, you are left unhappy. If you are drawing negligible watt-hours from the battery bank each day, a very small solar array can handle a large battery bank but then why bother dragging around a huge battery bank.
The question is how many watt-hrs do you use per day (w-hr = amp-hr * voltage).
A solar panel will produce around 4-5 w-hr per name plate watt rating...so a 100w panel will generate around 400-500w-hr on a typical day.
Then how many overcast days with minimal solar do you want to be able to go before the usable battery capacity is gone.
Let's say your fridge uses 50w and is on 50% of the time, so you need 50w * 24 * 50% = 600w-hr to service the fridge. (repeat for the other items that will be run of battery power and add them up to get the total w-hr).
If you want to go 3 days with overcast days, that's 1800w-hr you need in usable battery storage. For lead acid, you will need an overall rating of 3600w-hr (limit usage to around 50% of the rating) which translates to 300amp-hr @ 12v. Lithium you can use around 80% of the rated capacity.
Assuming you want to recharge the bank completely the next sunny day (1800W-hr), you will need around 450w of solar panels.
If you are only off grid for a couple days at a time or you are willing to use a generator occasionally to top up the batteries, you can reduce the size of the battery bank and solar panels..
When you come up with your final sizing, it's not a bad idea to upsize by 10-20% as the systems aren't 100% efficient.
