cliffy49 wrote:
Am I correct in assuming that a mppt charge controller that will accepts 100 volts and 20 amps would work with these panels.
I am currently trying to get a better understanding of charge controllers so your help is greatly appreciated.
It depends on the controller. Mine, when purchased in 2005 was top of the line. It only accepts 50 volts input.
There are *always* trade offs. The higher the input voltage the thinner the wire can be--BUT the MPPT efficiency may be lower.
One famous make says it will accept 100 amps. And so it will--but only if the battery bank is 48 volts.
In my opinion I would NOT do two 285 watt panels in series.
