MrWizard
Feb 10, 2018Moderator
technically correct
but
100,000 BTU per HOUR will produce 0.98 gal, propane contains 94,000 btu per gallon
a 3000 btu wave heater will need 32 hrs to produce that 'gallon' of water by burning a gallon of propane
a 5000 BTU heater will take 20 hours at full output to produce 0.98 gal of moisture
http://www.constructionheatersinc.com/catalog/combustion-moisture.html
naturally if you sleep with no heat, wake up cold, and light up a heater like a wave or buddy, the bit of moisture produced is going to condense on every cold surface in the camper, especially the windows
but if you keep a warm camper and the ventilation is sufficient, you are going to see very little as it will be exhausted with the warm air thru the ceiling vent
but
