GULFMAN
Sep 24, 2013Explorer II
dan-nickie wrote:
I guess I'm not understanding the problem, as it does not seem like a problem.
Connect your battery and turn on the battery switch and it works fine as it should?
Why would you be disconnecting your battery wire?
This problem (i guess you would call it) just started so i was just trying different things. Yes i can use the battery disconnect switch each time but never did before.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
