Switched from the green propane canisters to the proper hose for the Webber to use on a 5lbs propane tank. No extra changes were done. I light it, it works but the flame is blue and very low, just s...
I don't know. At first, I was hoping to run the grill directly from the 5th wheel where the hose runs in the back for a grill that came with the 5th wheel but after reading posts on low pressure and having to take the regulator out, I opted to keep it simple (I guess simple would be to keep using the green canisters) and get a 5 lbs propane tank and the hose that can be used on the webber. Going to try these ideas now. Thanks, I'll report back with results
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
