boubou64ExplorerJun 25, 2014Webber Q 100Switched from the green propane canisters to the proper hose for the Webber to use on a 5lbs propane tank. No extra changes were done. I light it, it works but the flame is blue and very low, just s...Show More
shum02ExplorerJun 26, 2014Run mine off a 20lbs cylinder all the time without issue. Certainly sounds like the safety check valve has turned on.Try another tank, even a 20/30lb and see if it repeats.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
Related ContentWebber q mount100 watt Solar decision$100 per night100 amp service100% Silicone vs Dicor
