Switched from the green propane canisters to the proper hose for the Webber to use on a 5lbs propane tank. No extra changes were done. I light it, it works but the flame is blue and very low, just s...
I believe those of you trying to use the grill off of your trailer are using a LOW pressure line that is not compatible with any grill with a built-in regulator. It must be hooked into a HIGH-pressure line before the tanks regulator to work correctly. There are ways to convert grills to work on LOW-pressure. Search the sire for how to do. Good Luck! Chino.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
