nlol's avatar
nlol
Wedgewood oven problem
Model RV1735SSPS mfg 2013
Installed 2015 Northern Lite TC
I purchased camper (virtually unused) 2019
Oven doesn't work. It appears the oven has never worked. Pilot and main burner do not light. Stove top burners work properly.
Trouble shooting: Oven control is fed gas through the same manifold that feeds stove top burners. Stove top burners work properly. Loosening the screw that holds the oven control unit in the manifold produces a leak that is easily lighted - so, LPG is getting to oven control unit. There are 3 lines from controller to oven: one line feeds the main burner; there are two lines to the pilot assembly - one copper, one aluminum. (The copper line is neatly pinched in a way that makes it look intended. Two lines makes no sense to me)
Loosening the control unit outlet lines and turning/depressing the oven control knob in the pilot, and all other positions, produces no gas at the controller's output ports. There is no gas at any of the 3 output ports. I've ensured the oven control is fully depressed and I've warmed the pilot light thermo-couple with a torch and get zero gas flow.
The lack of gas anywhere seemed strange and unlikely to me, however, a repair, or new control unit, appeared to be the obvious solution. I bought and installed a new control unit, hoping to repair and keep the old unit as a spare. The new control unit gives the same result as the original control unit; gas at the controller inlet connection, but no gas at the controller outlet ports no matter what control knob manipulation is done.
The obvious conclusion is that both control units are bad with the same fault. Unless I hear that this control problem is common, I deem that highly unlikely. That leaves me stumped. So please, can anyone enlighten me on what is wrong? Is there a known repair for this control unit problem?
