RCtime's avatar
RCtime
weepy, dirty HWH jack connections
On my HWH hydraulic jacks that control my 4 jacks and two slid outs, the connections at the pump and the rear slide out jack get filthy from weeping oil and dripping.
I want to get under and tighten all the fittings, but what can I expect?
I have never ventured into this part of my motorhome repair before.
  • that depends on the year and manufacturer. they make the decision where to put the pump. mine is a 2005 36 ft itasca meridian, and the pump is under the step. on my 2002 39 ft chieftain, it was under the front of the slide out like you described.
  • Fleet Man wrote:
    Have you checked to see if you can access the back end of the pump from under the entryway steps? I can get at most components of the HWH pump, motor and solenoids from there. However, I did have to get under the coach to change a pump motor solenoid.
    They must have changed location of the pump from 2002 -2007.
    Mine is accessible by lifting the storage bay door on the front slide out. Everything is pretty much in front of you.
  • Have you checked to see if you can access the back end of the pump from under the entryway steps? I can get at most components of the HWH pump, motor and solenoids from there. However, I did have to get under the coach to change a pump motor solenoid.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
