YC_1
Jun 17, 2013Nomad
Could be you reversed the polarity and some devices are protected. Some just won't work. Or, your wires are not carrying the current load and the voltage is dropping.
Grab a voltmeter and touch the outside edges on each of the sockets. If you see voltage the new one is reversed. If it is a low voltage issue you need to measure the voltage right on the back side of the socket while under load.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
