alliemac9's avatar
alliemac9
Weird 12V question for you electric gurus...
I'm hoping you guys will be able to troubleshoot this for me as I am totally baffled...
Background:
-In our former TV cabinet, we had a 12V outlet on the same plate as the coax jack. It didn't work. Took it out and found there were no 12V wires attached whatsoever. Bummer.
-Beneath our former TV cabinet, we had the standard coax jack with the antenna amp button. No 12V outlet there. I saw the combo plate online and ordered it several years ago. But, when I removed the existing antenna amp plate the 12V wires only read ~8V on the multimeter. Huh? Abandoned that plan and just lived for a few years with no 12V outlet in coach.
Current:
-Getting geared up for solar install. Would like to install some 12V outlets (plus my control panel battery readout stopped working, so would like a 12V outlet to use with my cheapy 12V plug in meter until the TriMetric is installed). So, I revisited the 12V wiring situation, and found the following:
--->The antenna amp plate still reads ~8.xxV (we've never used the antenna or a TV).
--->The light above the sink (just a few cabinets down from antenna amp plate (maybe 5 feet max) reads 6.xxV????? The LED light I installed works.
--->Decided to check voltage at charger/converter (WFCO WF8955AN) and found the ~8V circuit. Pulled the fuse and it was blown! Have no idea how/why a blown fuse was passing partial voltage. Replaced fuse and now have 12V to the antenna amp plate. Yay! Installed and now have one functional 12V outlet in coach!
My Question:
-Any ideas about the 6V at my light? I didn't unscrew any other lights to check them...I kind of threw in the towel for the night. All the other circuits on the charger/converter seem to be okay (i.e. match the battery output which was about 12.9V if I remember correctly).
-I did the above testing on battery power only. Should I plug in and see if there is a difference? Any other ideas?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
