chuggs
Oct 13, 2014Explorer
Btw...nothing should smoke... The results are the same as if you plugged your RV into a 50 amp outlet using a doggone adapter...which I have done many times. The RV's power center 30 amp breaker will trip if your camper draws too much power.
I'm wondering if someone uses that outlet to run a welder when there isn't a camper there...and they rigged the box for that purpose. It's not unusual to put larger breakers on smaller gauge wiring for welders due to the intermittent duty cycle. My welding outlet is labeled WELDER only! I have a 100 amp breaker to prevent nuisance trips when using the TIG welder... That's NOT to say I endorse anyone rigging an RV pedestal this way...
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
