chuggs
Oct 13, 2014Explorer
Power pedestal document
Page 25 of this document has a normal wiring schematic for a common 50/30/20 like the PM137 series...
...edit...oops I didn't see that you said there was no 50 amp outlet...my bad.
If you turn OFF the 50 amp breaker...and turn the 30 amp ON and the 20 amp ON...if you get no power from any outlet...
Then turn the 50 amp breaker ON...and everything works...
As a final measure...turn OFF each respective 30 amp and 20 amp breaker to see if it interrupts power to the individual outlets... Then it's wired correctly with a 50 amp limiter on the boxes bus bars...
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
