MEXICOWANDERER
Oct 13, 2015Explorer
If you dig at any of these sites you will find ancient burial grounds for forty years worth of rigs who didn't have the protection afforded by an EMS. Cross the Rio Bravo, with an EMS and prepare to boondock the whole trip because the device will shut down if you plug into a 15 amp receptacle.
We Neaderthals have to check outlets manually before plugging in, make our own earth ground then monitor a volt gauge occasionally to see what we can run. Converters tolerate low voltage and once they top off the battery it free's-up another few hundred watts for general usage.
Course the escalator don't work and hot water has to be heated by (gasp) LPG which means the thermlstat has to be turned down so (2nd gasp) there is no hot water at 0315 hours.
It's intolerable I tell ya...
Hope this made you smile. :)
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
