MNRon I have the Magnum hybrid 3000w inverter/ charger for over 5 years now using everyday (fulltime 99% boondocking). I can use either my eu2000i or eu2200i to run the Carrier Air V 15k air conditioner at elevation as high as 6,000' with outside air temps in the 90's range. I did add a micro-air 365 to the A/C unit which made all the difference, before the micro-air it was hit and miss. I set the "loadshare" to 16a when above 5,000' this keeps the Magnum from faulting, but with your larger generator you shouldn't have a problem getting one going.
I also run my A/C off just batteries/ solar assisting for a few hours at times. I'm using LiFePO4 batteries which helps.
Here are the setting I've used since day 1 on the Me-Arc50 for the Inverter.
Favorites (can be changed to personal taste)
F1_ Bat amps - PT ADC (present be produced)
F2_ AC output - 121 VAC/ 60.0 HZ
F3_ AC input - Amps= 15a (adjustable with incoming power)
F4_ Load amps - 0 amps AC
F5_ AC Amps - -2 amps
CRTL
01_ AC in Control - Auto Connect
02_ CHG Control - Multi Stage
03_ Gen Control - Off
04_ PT Control
• a_ PT Chg CTRL 1 - Multi Stage
• b_ PT Aux Relay - Control= Disengage
• c_ PT Alarm - Control= Off
• d_ PT Mppt Ctrl - 15 min sweep
METER
Inverting_ DC (present time reading)
01 DC Meters
• a_ DC volts (present time reading)
• b_ DC amps (present time reading)
02 AC Meters
• a_ AC output (present time reading)
• b_ Load amps (present time reading)
• c_ Input AC (present time reading)
• d_ Inv/ Chg amps (present time reading)
• e_ Input AC1 (present time reading)
SET UP
01 System Set up
• a_ Set Clock
• b_ Screen set up (press select) _ Brightness (50%), Contrast (100%), Power save (1 min)
• c_ Temp select - Fahrenheit
• d_ Max charge- Amps 200 adc
• e _ Link PT Chg - setting - yes
02 Inverting/ Inverter set up
• a_ Search watts - Off
• b_ LBCO setting - 12.0 vdc
• c_ AC In time - 6:00am-6:00pm
• d_ AC In VDC - 11.O-14.1 vdc
• e_ AC In SOC - 80%-100% SOC
• f_ Power up - Always off
SET UP INVERTING
03 Charger Set up
• a_ AC Input - Amp= (can be set to available shore power/ generator incoming power)
• b_ VAC Drop out - 80 VAC
• c_ Battery type - Custom (with in here absorb voltage can be adjusted)
• d_ Absorb done - Time= 0.1 hrs (minimum, can't be turned off)
• e_ Max charge - Rate= 100%
• f_ Max charge - Time= 12.0 hrs
• g_ Final charge - Stage= Multi
• h_ EQ Reminder - Days= Off
04 AGS SET UP - No AGS Present
05 BMK SET UP - No BMK Present
06 PT SET UP (Magnum pt controller follows Magnum inverter settings)
• a_ Battery Type - Linked
• b_ Absorb Done - Linked
• c_ Maxed Charge - Rate= 100%
• d_ Max Charge - Time= 12.0 hrs
• e_ Bulk Start (press select)
- select Bulk Start, Daily / sun up= yes
- set Bulk Start, Volts= 12.0
- set Bulk Start, SOC= 80%
• f _ PT Aux Relay - 10.0 to 14.0
• g_ PT Alarm - 10.0 to 14.0
• h_ Power Save PT - Display= 15 min
TECH
01 Temperatures (press select_ scroll)
- Inv BTS (present time reading)
- Inv TFMER (present time reading)
- Inv FET'S (present time reading)
- AGS Sensor 0ff
- ACLD Temp 32f
- PT BTS (present time reading)
- PT Inductor (present time reading)
02 Versions (press select_ scroll)
- Inverter: 1.2
- Remote: 4.0
- AGS: 0.0
- Router: 0.0
- ACLD: 0.0
- PT: 1.1
03 Inv Model - MSH3012H (3000w hybrid)
04 Fault History
05 Set up pin
06 Ext Control - No ext control
07 Show all - Menus= No
08 Load Defaults
The following parameters are for programming the ME-ARC Version 4 advanced control.
Setup 02B LBCO Setting: Volts = 12.0
Setup 03C Battery Type: = Custom
Set Absorb Volts: = 14.1v or 14.2v (depending on season)
Set Float Volts: = 13.6
Set EQ Volts: = 14.1
Set EQ Done Time: = 0.1
Setup 03D Absorb Done Time: = 0.1 (minimum)
Setup 03E Max Charge Rate: = 100%
Setup 03G Final Charge Stage: = Float
