MNRon
Jul 17, 2021Explorer
Westinghouse i4500 Generator
I posted a few weeks ago about trying to run my AC with a Yamaha 2k genny and Magnum 3000W boost inverter. Sort summary - the Yamaha just wasn’t strong enough with surges to work.
So now I’ve purchased a Westinghouse i4500 which we just picked up today in Salt Lake. It’s 100deg out so I expected I could run my AC, maybe both ACs with the boost inverter…no joy :(
Altitude here is 4200ft so I don’t expect the full 3.7kW static performance but still it should start and run an AC!??!!
By playing around with Magnum control settings I can nurse the genny (with Magnum boost support) to start one AC once in a while (Magnum VAC dropout=60v, AC input limit=20A; manually start AC fan on low early; etc). Still have to futz with it a dozen times or so to get success. When running the Westinghouse shows it’s providing 2.3k power (AC, fan, converter).
But even when I nurse it up on one AC it only ran an hour then kicked out, a half hour the second time. Just spent 10min getting things going again, hopefully longer this time but we’ll see. When it kicks out the boost inverter takes over and keeps the AC and fan running by drawing about 170A from my batteries. Not sure why genny kicks out as it doesn’t show overload, just reduces to 0power and the Magnum timer to kick it in starts dancing with the genny but it doesn’t ever come back in.
As I’m typing, the genny just kicked down to 1.3k power and my Magnum is supplying load support of 50A from batteries for a couple minutes; then genny went back up to 1.7k and is running the AC on it’s own again.
Anyone have a clue what’s going on, and why the Westinghouse can’t start and run an AC on it’s own?
