mike-s
Jul 18, 2018Explorer II
MEXICOWANDERER wrote:Do you have a coherent point? To get a 5 volt source to move 5 mA, the resistance would be 1000 ohms. Any voltmeter is magnitudes higher, as I said, 10,000,000 is common. Not that that has anything to do with anything - you claimed putting a voltmeter across the (bad) fuse would kill the LED. It won't. You only know enough about electronics to be dangerous, as you prove time and time again in your unique form of gibberish.
5 MILLI amps of bleed can cause a 5-volt potential exist in a switched buss, try it with reality instead of a calculator and sharp pencil.
