Cydog15
Jul 19, 2018Explorer
mike-s wrote:MEXICOWANDERER wrote:Do you have a coherent point? To get a 5 volt source to move 5 mA, the resistance would be 1000 ohms. Any voltmeter is magnitudes higher, as I said, 10,000,000 is common. Not that that has anything to do with anything - you claimed putting a voltmeter across the (bad) fuse would kill the LED. It won't. You only know enough about electronics to be dangerous, as you prove time and time again in your unique form of gibberish.
5 MILLI amps of bleed can cause a 5-volt potential exist in a switched buss, try it with reality instead of a calculator and sharp pencil.
I think both of you are doing a discredit to the OP and readers and haven't taught anybody ****. Maybe stroked your ego a little. He didn't ask anything like that. You guys are having a tech discussion within general questions about simple stuff and look like idiots to us trying to learn the ANSWER TO THE EFING QUESTION THAT WAS POSTED. I'd start with teaching how to use a multi meter. How helpful would that be?
