jgiuffre's avatar
jgiuffre
WF 8955 converter 12 volt fue panel problem
The problem is not the converter.
The problem is in the 12volt fuse panel.
I have voltage on the side that shouldn't have any when the fuse is removed. about 10 volts
It does it on all fuse slots
Also one of the red lights is on even when the fuse is good.
  • First, you need to post this to Tech Issues.
    I would suspect a grounding issue or bad connections. Something is back-feeding somewhere. It may not necessarily be in the fuse panel.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
