pianotuna
Sep 12, 2015Nomad III
You can attempt to remedy the situation by increasing the cable size from the wfco to the battery bank. Try #2. You can move the converter closer to the battery bank using thicker wire. Neither of these suggestions work all the time, or even most of the time.
You MIGHT be able to pop the box and twiddle some internal knobs, but don't do so unless you are fairly expert. You may let out the magic blue smoke. In which case you may want to change brands.
