marcus6701's avatar
marcus6701
wf 9855an blown fuse
The converter in my TT has a blown fuse on the circuit board. A 15amp fuse that is not cannot be removed to be replaced. Anyone come across this? Had the TT connected to a 20amp GFI at our house but was not running anything. Just left it to keep the battery volts up. Lost power a few times from storms although we did not get rain. GFI never tripped. Going to get a new converter. Unfortunately leaving tomorrow for 4 days. Propane fridge and battery power I guess.
  • I would solder in a new fuse, maybe on a removable holder as mentioned, just to get you quickly through this trip. Then immediately order a powermax boondocker. I replaced my wfco with one last year and am very happy with it.
  • Now you know why they sell new circuit boards for Wfco by the dozens.
    Don't waste your time on it.
    The 87 and 8900 Wfcos were junk when they made them, caused a lot of Rver's a lot of grief, and after years, they didn't get no better.
    This may have been an isolated incident with a surge after power was restored, or it might be a hard failure of the converter. The only way to find out is to replace the fuse and see if it blows again. The fuse may not have been made to snap in and out but it can be replaced. Does it look like a standard glass fuse with short pigtails coming off the ends that are soldered to the board? Try putting another 15A fuse across the existing one and soldering it in. Or put an inline fuse holder across the blown one.
    Steve
  • RoyB's avatar
    RoyB
    Explorer III
    Keep in mind your trailer is required to have a working battery to operate your electric brakes in case of trailer being disconnected when being moved as per State DOD laws...
    Just a reminder in case your leaving for the next few days involved moving the trailer or not...
    Roy Ken
  • Hi,
    Be sure to take along a battery charger!
    I would go to one of these three: Iota, Progressive Dynamics, or Power Max boondocker.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
