Lspangler's avatar
Lspangler
WFCO 8955 question
I have the famous WFCO converter charger in my Rockwood Windjammer.
Over the weekend we camped 4 days on 2 golf cart batteries. With quite a bit of furnace use we got down to 12.1 volts. When we got home and plugged in the voltage at the battery went to 12.9. We left after about 10 minutes but shouldn't the charger have gone higher than that? How long would it take to charge the battery at that voltage?
Linc
  • hmknightnc wrote:
    Mine actually goes into boost quite easily
    Does it stay there until the batteries are charged?
  • The plugged in voltage at the battery was 13.2 when I picked it up thursday so I would have expected it to go higher than that when first plugged in.
    My plan is to upgrade the wire and the converter soon. I just thought it was odd that it only went to 12.9
    Linc
  • Your WFCO is not going into boost must likely due to too small and to long a wire run to batteries. Like somebody else said run some much heavier wire, as heavy as will fit in the WFCO connections
    I'm on of the lucky ones with the WFCO. Mine actually goes into boost quite easily if the batteries are low but my wire run is only about 5' and came from the factory with #4 wire.
  • What exactly do you think the WFCO is famous for? ;)
    You also have close to 0.7 volt drop in the wire from converter to battery :(
    Pull some #4 along with installing a new converter.
  • That model charger rarely will go into boost mode, 12.9V was all it could put out based on the amp draw and voltage loss.
    12 hours
  • at 12.1 volts the batteries are very low the charging time will depend on the charging rate of your converter. but 10 minutes is not even close to being long enough.imho
Having RV issues? Connect with others who have been in your shoes.24,313 PostsLatest Activity: Sep 08, 2025
