Randemgun wrote:
When I cut the gen off and plug in to shore power nothing works. When plugged in to shore power I get 110 to all my breakers in the converter but none of the 110 plugs, the ac or microwave work.
Which is it?
Its 30 amp service since the 8900s are all 30 amp (at least I think) and its not 240 or you wouldn't have got this far but the flickering/dimming before sounds like a failing WFCO, see it on here all the time.
It sounds like a transfer switch is stuck latched to the primary side (Generator)and the converter is now failed as well. Call Randy at bestconverter.com and I bet he'll tell you in 2 minutes.
