Randemgun's avatar
Randemgun
WFCO 8965 converter
I have a 8965 WFCO converter and a Onan 3600 generator for my horse trailer living quarters. Here are my symptoms. When running the gen all the 110 side works but not the 12V side. The 12v only is working off the battery. When I cut the gen off and plug in to shore power nothing works. When plugged in to shore power I get 110 to all my breakers in the converter but none of the 110 plugs, the ac or microwave work. When I call wfco they tell me the 110 shore power does not go through the transfer switch and don't understand why nothing is working on the 110 side if I am getting 110 at the breakers. I also discovered that with my GFCI in the bathroom (which is next to the converter) that when the gen is running the gfci works as well as everything 110 and I have 110 on the black wires and nothing on the whites (when metering the white and ground BUT when I am plugged into shorepower I get 110 on all four wires. Blacks and ground 110, whites and ground 110 and the gfci does not work. Banging my head on this one so any help is greatly appreciated.
  • Is this a NEW problem?
    Has 110V AC worked on shore power and from gen in past?
    Has 12V DC worked when on AC power and when not on AC power before?
    Horse trailer...is this a 'commercial install' or a 'home install'?
    AC shore power comes into one side of 'transfer switch'
    Gen AC power comes into one side of 'transfer switch'
    AC power to rigs AC Panel comes out other side of 'transfer switch'
    (Transfer switch flips from one input source to other)
    AC Panel (with circuit breakers)
    Power comes from transfer switch to MAIN CB (30A or Double 50A0
    Hot Bus feeds individual CBs to A/C, Microwave, outlets, 'converter'
    Converter takes 110V AC power input and converts to 12V DC output
    Battery cables connect to converter bus
    Bus feeds individual fuses to lights, water pump, furnace, fridge/water heater controls etc.
    Converter supplies DC system when on AC power source
    Battery feeds DC system when not on AC power
    So if gen feeds AC Panel----then converter should be feeding DC System unless converter has failed OR AC input CB has tripped
    When swapped over to shore power.....either you have AC power from transfer switch or you don't.
    Can't have AC power at AC Panel and not thru individual CBs unless MAIN CB has tripped (or individual CBs are tripped)
    DC System is feed from converter or from battery...unless battery is dead, disconnect switch is OFF or 'reverse polarity' fuses on converter have blown
    Start with just battery....no AC and check that DC System works
    Then check with one AC source and check voltages on both AC/DC System
    Then swap to other AC source and repeat checks.
    One system at a time....
  • Are you plugged in at home? Is it a regular 110v outlet or is there a chance you plugged into a dryer outlet?
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 23, 2026
