Moffittclan
May 11, 2016Explorer
Wfco converter - solved
Just posting what I found when my lights were dimming every couple of minutes after researching on other forums and on here. Most research led to me to believe it was the converter but could also be bad batteries in or couple other things. So my first choice was to remove the batteries and have them tested. I did find one bad battery (out of 4) and 2 batteries low on water. I replaced the one and added water to the others but the lights keep dimming. So I pulled off the cover over the converter and it appeared there was Mouse Nest or something all around the fan of the converter keeping it from turning. I cleaned out the nest and got the fan turning and now I've got solid lights. It appears the converter was overheating and not being able to cool itself.
Just posting in case others are researching in the future.
