scubadvr
Feb 01, 2018Explorer
It is a fuse that pops, not the breaker. Similar to the ones in a car. 12v DC circuit fuse. Sticker says its for the Charge Line, slide motor. I have no slide. The Reverse Battery Protection Fuse 40 amp, is not popped.
With battery disconnect, and shoreline plugged into a confirmed house 110 outlet, i have one outlet inside the RV that works. A GFI near the sink. I get no sound from the converter set up this way, no fan spinning. All other breakers and fuses are ok.
If not a WFCO, then what?
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
