time2roll
Feb 01, 2018Nomad
The 30a battery fuse might open before the 40a on reverse polarity.
With a 35 amp converter I think that battery fuse s/b 40 amp also but oem does tend to under size these at times.
My battery fuse was 50a for a 55a converter. The weak WFCO never really did even 50 amps into the battery.
+1 for the powermax listed above. Although it is a deck mount so you will need to slide the power center out and mount it behind someplace. Easy job.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
